Home > General (L494) > Difference between KPLA- JPLA- GPLA |
Limited knowledge but
Thu Sep 09 2021 5:05pm |
Terras14 Member Since: 04 Mar 2018 Location: Singapore Posts: 38 |
Awesome. Thank you🙏 |
Fri Sep 10 2021 12:54pm |
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 409 |
As Peachy said sometimes its down to regions such as US market or UK market or the year it was fitted, in fact those numbers are not acutall LR part numbers they are part references as LR part numbers are always LR******* (often one part might also supersede another
Fri Sep 10 2021 7:54pm |
Hi pjbracer1,
Sat Sep 11 2021 10:48am |
If its the can bus then it just wont work so I think you are good there, the langauge might be set in the digi display but if you have a GAP diagnostice IID tool I bet it could be changed? All UK cars have the TFT dash I think. Or maybe someone nearby has access to JLR SDD software that re-program it I suspect it might have its onw ROM and so defaults the original country and lang it was destined for. If a jobs worth doing, get a someone who knows what they are doing to do it!
Sat Sep 11 2021 2:41pm |
Thank you. I bought another one and hopefully it will work. |
Sun Sep 19 2021 2:02pm |
did it work in the end? If a jobs worth doing, get a someone who knows what they are doing to do it!
Mon Oct 04 2021 11:46am |
Hi there. Yes. The second one I bought has the same fuel type, rhd and had the GPLA reference digital gauge. It works and everything function except the mileage on the digital cannot be programme to my car. So the mileage on the dash is that of the previous car. Except for that all works. The first one also works but I stop when the one doing the install inform me that the language cannot be changed. Just a quick note. My car dash only has one wire and the digital dash got 3 hole. I only plug in one wire and leave the other two empty. I suppose other car comes with 3 wire. But then the digital screen still works. |
Mon Oct 04 2021 12:41pm |
Cool I guess you might need to get a dealer to reset the mileage for you (I'm sure they will charge for this as it will be a legal thing). Not sure If Singapore has an MOT like the UK but this records the mileage so if there wasnt much difference and the new digital display had more miles on it, it would just look like you did a lot of miles that year but if it has less then either the car needs to be reset or the paperwork needs to have an adjustment/ correction for the difference. Good that it works though If a jobs worth doing, get a someone who knows what they are doing to do it!
Mon Oct 04 2021 2:30pm |
Hi there. Yes I intend to ask my dealer to adjust the correct mileage for me when I next send it for servicing as it is the most right things to do and hopefully they will agree to it and not ask me to FO.
Tue Oct 05 2021 2:36am |
