Home > Technical > brakes drained out
mjpuds
United Kingdom 2009 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
brakes drained out
OK hello all.. Right I'm now a owner of a 2009 RRS 90.000..., 4 hours old. Well looked after . Fsh.. but on the way home after buying it brake light came on. On getting home I checking and massive leak under the car of brake fluid. Res was empty. Any clues .. looks like leak is coming from under main center under tray . i havent had time to remove due to not having a jackk strong enough to fit the beast.
Post #617042 Mon Sep 06 2021 10:36am
First question did you buy it privately or from a dealer? if dealer straight on the phone to them, tell them to come and collect it and repair it.
Post #617044 Mon Sep 06 2021 10:48am
You usually hear of them leaking at the rear due to rusty brake pipes.
Never heard of a front leak.
Check the plastic tank. There is a small tube take off that should be crimped. Check it’s not leaking there.
Post #617045 Mon Sep 06 2021 11:59am
