Home > Technical > Brake problem |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
My brakes always seem very good both a low and higher speeds. They give full confidence to know they are capable of stopping 2.5 tonnes properly. Nice and steadily - progressive as you increase the pressure on the pedal. I would certainly be looking a the servo (perhaps a leaky hose???) but perhaps a trip to a local good indie would avoid you buying one bit after another until you find the problem. Robin
Tue Aug 31 2021 3:05pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Isn’t there a thing about oil in the brake reservoir, perhaps something to quickly have a peek. 2006 2.7 TDV6 HSE in Cairns Blue. |
Tue Aug 31 2021 5:34pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
Could well be a seized caliper, especially a rear one. Be worth asking your usual indie LR garage to have a look. The problem with seized calipers is that if it's the one that has the brake wear sensor on it, the first you know there's a wear problem is when the other corner starts making expensive noises. Ask me how I know... 2012 SDV6 - it's missing a couple of cylinders
Tue Aug 31 2021 10:01pm |
