![]() | Home > Maintenance & Modifications > Scandalous RR Main Dealer charges |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4453 ![]() ![]() ![]() |
That's why decent indy garages are boo |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9053 ![]() ![]() ![]() |
Ah the old "your brakes are worn out/dangerous and should be changed" money-grabbing lie. It's a standard LR main dealer(*) game-play in order to make a few hundred quid for very little work.
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 544 ![]() |
Recently had similar…booked my G4 D3 for a service to keep the history up…as luck would have it the ignition light illuminated en route to the dealer indicating the alternator decided to end its life….
Unless you have a LR warranty then avoid main dealers and find a decent local independent LR specialist is the #1 advice I give to lots of people all too frequently |
Unless the warranty is the original manufacturers warranty, you can still go elsewhere. LR's aftermarket warranty will deal with indies so there isn't a need to use the dealerships with that one. 2012 SDV6 - it's missing a couple of cylinders
