Home > General > Day lights
Kitchenfitter
Day lights
Hi is there anyway the lights can be on at all times ... without turni g on manually
U have a 2012 L320 Autobiography
Post #616818 Thu Aug 26 2021 2:11pm
idi
https://www.rrsport.co.uk/forum/topic55116.html
Post #616819 Thu Aug 26 2021 2:12pm
Kitchenfitter
Looks confusing lol
Post #616823 Thu Aug 26 2021 4:59pm
If you have an IIDTool then you can set the car to use Scandinavian / Canadian lights. These are on all the time.
Worth bearing in mind that if you do these mods, the main beams don't work until you physically turn the light switch to dipped beam setting i.e. lights on. 2012 SDV6 - it's missing a couple of cylinders
Post #616824 Thu Aug 26 2021 5:59pm
Kitchenfitter
Thanks Steve
Post #616827 Thu Aug 26 2021 8:02pm
I posted this a few years back, it show how the different CCF settings change how the lights switch on.
Have gone into the CCF files and there are three options listed on my car a MY13 A/B 5.0L S/C.
1. DRL Standard
2. Scandinavian
3. Canadian
I activated Standard and all that did was give me two Fault Codes B124A-15 and B124B-15 which are Left and Right Daytime Running Light open Circuit but no working DRL's so it may be when you have either DRL lamp kit VPLSV0064 or 65 fitted you may have to activate this but that is purely a guess. By the way those kit's are over �400.00
De-activated that and then activated Canadian and what that did was nothing with ignition on and Engine Running, however when you engage Drive and let the Park Brake Off it Switched Front and Rear Side Lights and Dipped Headlights On, as soon as you apply P/B and take it out of Drive It switches them Back Off.
Again De-activated that and Activated Scandinavian and what that did was as soon as you Start Engine it Switched on Front and Rear Sidelights and Dipped Headlights. (Muddy was correct there).
There is no facility that I could find to just activate the Front Fairy Lights on there own as DRL's.
I hope that all makes some kind of sense.
Post #616829 Thu Aug 26 2021 8:55pm
