Home > General (L494) > Tailgate out of alignment
PC76
Hi all,
I was getting a bag out of the boot and pressed the close button on the bottom of the tailgate, when it closed it was approx 1/3 of the way down and then stopped and opened again. I tried again and there was a resistance in one of the struts but as I was in a petrol station I needed it it to close so as gently as possible helped it passed the point.
It now catches the latch as if it dropped slightly and doesn’t sit squarely when closed.
Has anyone had this before ? 2015 4.4 Autobiography
2010 3.0 HSE 162K - Gone
Post #616752 Mon Aug 23 2021 7:37am
PC76
Hi all,
shameless bump alert. I have been away for two weeks and it seems to have settled a little in the time and now shuts without catching the lock but still looks twisted as doesn’t sit squarely when closed.
Is this be cause one of the struts internals a knackered or can they be re-aligned? 2015 4.4 Autobiography
Post #617026 Sun Sep 05 2021 11:16am
pjbracer1
I think the tail alignment was an issue on most l494 from the factory they all seem to look a bit low along the line.
Powerfuluk did a video on how to adjust it if you are brave enough! its a rear spolier off job but once that is the done the rest seems pretty stright forward but will require some fetlling! If a jobs worth doing, get a someone who knows what they are doing to do it!
RRS Autobiography Indus
RR P38 HSE V8
RRS Supercharged Santorini
AMG CLK Rear Tyre Shredder
Post #617158 Fri Sep 10 2021 7:56pm
