![]() | Home > In Car Electronics > HDC indisponible |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9025 ![]() ![]() ![]() |
It could be a low battery - check that the battery is well charged.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Battery old or discharged |
Miche2b Member Since: 15 Nov 2014 Location: Corsica Posts: 3 ![]() ![]() ![]() |
Hello,
does it come on at every startup? |
No; sometimes |
I would just ignore it.
Mafya Member Since: 05 May 2020 Location: Sheffield Posts: 46 ![]() ![]() ![]() |
If you have dynamic response check the fluid level as I had a similar issue and the fluid was low due to a leak in one of the ace bars |
