Home > General > After recommendations for 4 wheel alignment South Wales
Wafoo
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Baltic Blue
Hi all, had my fronts replaced 275/45/20's replaced about 6 months ago, I noticed the wear on the nearside front was uneven, the outer edge was shot, told the guy to adjust whatever they adjust to bring it back in, he said he'd took it as far as he could but the nearside front is going again, is there anywhere in the South Wales area that does decent Alignment ,there's no Hunter garages showing on their website
TIA
Post #616154 Mon Jul 26 2021 10:01am
Stevepd
Hiya try this
https://alignmycar.co.uk/ 2006 2.7 TDV6 HSE in Cairns Blue.
Post #616159 Mon Jul 26 2021 3:06pm
Wafoo
Tried it, nowhere in South Wales 😢
Post #616166 Mon Jul 26 2021 10:41pm
knwatkins
There are quite a few around. When I lived in the area, I used to use a place in Cwmbran who used to use Hunter machines but they closed down.
Here's some other places that have Hunter, but I haven't used them:
Motec, Pontllafraith: https://www.mototec.co.uk/wheel-alignment/
Ystrad Service Centre, Ystrad Mynach: https://ystradservicecentre.com/about-us
ETB Tyres, Cardiff: https://www.etbtyres.co.uk/cardiff/
A&A Tyre Services, Cardiff: http://www.aatyres.co.uk/services/Wheel-Alignment-faq.php
Euro Performance, Llantrisant: http://www.euro-performance.co.uk/
Indigo GT, Ystrad Mynach: https://indigo-gt.com/wheel-alignment/
PARC, Pontypool: https://www.pontypoolaccidentrepair.co.uk/...alignment/
Just make sure they put the air suspension system into tight tolerance mode with a suitable diagnostics tool prior to performing the alignment. It's probably worth asking them if they are familiar with the procedure when you ring around. That should either give you confidence, or not. Kev
Post #616181 Tue Jul 27 2021 6:58pm
Wafoo
Brilliant, thankyou 😊
Post #616185 Tue Jul 27 2021 10:23pm
