Home > Technical > Fault codes
hoppy89
Fault codes
evening all,
just had a diagnostics on the car... any help on fix for the code's would be greatly appreciated, or if anyone's had the same issue's
run my iid tool and the codes in the pictures came up.. ive cleared them a few times, but when i next give it a run the
"stop engine" pings on the dash
Post #615954 Tue Jul 20 2021 6:54pm
Disco_Mikey
You've an issue with the hydraulic pressure in the ARC system. Have you checked the fluid level?
Post #615955 Tue Jul 20 2021 7:06pm
hoppy89
hi mikey, yes fluid level is as should be
Post #615956 Tue Jul 20 2021 7:11pm
