gogsy1956
Sounds like you've been lucky,,, depending on how you look at it,,,, at least both sides weren't siezed solid and you've managed to get the discs off. The screeching noise will be coming from the plastic gearing inside the module,,, trying to pull on a none moving cable, it maybe the adjuster has wound up too far causing the brakes to size. Whatever it is clean and lubricate moving parts and make sure the adjusters are free to turn and wound back, then adjust correctly and hopefully all will be ok. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
