Home > General > Anti roll bar removal without lifting the shell |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9006 |
I believe it has to be lifted a bit (a couple of inches or so) although it doesn't require the whole body to be fully removed. 2012 SDV6 - it's missing a couple of cylinders
Thu Jul 15 2021 9:56pm |
eddyeggs Member Since: 03 Nov 2020 Location: luton Posts: 13 |
Hi , so the question is can the body be lifted without a 2 poster lifter can it be done while on the floor |
Thu Jul 15 2021 10:04pm |
No idea, I'm afraid as I've never done it. I believe some have done it at home so presumably it is possible with a suitable jacking device. 2012 SDV6 - it's missing a couple of cylinders
Thu Jul 15 2021 10:05pm |
Ok thank you, hopefully someone will jump in and let us know, take care |
Thu Jul 15 2021 10:13pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Body can be lifted with jacks Kev
Fri Jul 16 2021 1:31pm |
iforland Member Since: 13 Apr 2015 Location: Redditch Posts: 47 |
Did the job last weekend on the drive, used 2 bottle jacks to lift body (had to place them on some railway sleepers because I had the car up in the air on axle stands....
Fri Jul 16 2021 5:25pm |
Guys thank you so much for your advice, at least I know it can be done without the whole shell being lifted at £2000 |
Fri Jul 16 2021 7:04pm |
Hi sorry you mentioned a guide are you able to share that in any way, also what was the best price for the anti roll bar |
Fri Jul 16 2021 7:15pm |
Bailey9814 Member Since: 11 Sep 2024 Location: Guernsey Posts: 2 |
Hello also interested in the guide for removing ace anti roll bar without lifting body. Thank you
Thu Sep 12 2024 3:17pm |
