Home > Faults & Fixes > Oil Pooling on Oil Cooler
djpgowrie
I'm having an issue where over a period of time (really, quite slow) oil is pooling on top on my oil cooler in the grooved area and also down either side deep into the V of the engine block. There's also a lot of oil splatter much wider around the area under the whole of the throttle body (including the underneath of the throttle body itself).
I dont seem to have any ODB error codes related to it and no engine light, it drives great and shows no drop in oil level.
Speaking to some guys at work and doing a bit of googling leads towards a breather pipe/PCV valve issue? I have another thread about a broken pipe from the turbo to the airbox that may or may not be connected? https://www.rrsport.co.uk/forum/topic58364.html
Any additional thoughts?
Post #615685 Mon Jul 12 2021 7:28pm
OvalAutos
https://www.rrsport.co.uk/forum/topic58445.html Joe
Post #615698 Tue Jul 13 2021 7:40am
djpgowrie
Awesome! Thank you!
Post #615706 Tue Jul 13 2021 9:20am
