![]() | Home > In Car Electronics > Successful L320 (2010>2013) Carplay Installations? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5062 ![]() ![]() ![]() |
I think at one point they did two different versions, one which is just plug and play and one which is integrated in to the sat nav unit, the one I have is the plug and play version for the MY12/13, looks like you may have the integrated version for the slightly earlier cars.
AndyCHO Member Since: 23 Dec 2021 Location: Wodonga Posts: 125 ![]() ![]() ![]() |
Yep, 2 different units... the latter is a Bosch and has different wiring setup etc.
Have to admit that was my thought's on if lost any use of the original set settings/menus etc. but only seems like navigation side that is affected, but then the latest NZ maps available for o.e sat nav is 2017 so not going to loose much.
Darkangelv2 Member Since: 01 Jul 2021 Location: Romsey Posts: 25 ![]() ![]() ![]() |
Hi Andy Glad to see someone taking it on - agreed, it does look quite daunting compared to some I’d seen for the other years. Please do let us know how you get on. If it all works I might have to pull the trigger! The UK sellers are still not finished with their 2010-11 model. |
I havent had a chance to even get started on it yet... Life has been getting in the way.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5036 ![]() ![]() ![]() |
Powerful have done several videos, small and large display.
AN UPDATE FROM UAD
Adrian Clarke Member Since: 09 Apr 2022 Location: Warwickshire Posts: 4 ![]() ![]() ![]() |
Old thread, new member. I’ve just bought the Unique Audio kit and will be installing it this afternoon. I have a 61 reg L320 with the Bosch media system. Can post pictures and report back later if anyone is interested.. |
Ken 153 Member Since: 02 Sep 2021 Location: Sheffield Posts: 189 ![]() ![]() ![]() |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 204 ![]() ![]() ![]() |
The install was easy, I fitted to a MY12 L320 a few weeks back. Some advice, order a longer 3.5mm cable with a 90d end for the aux input in the rear of the arm rest. The one that shipped was too short and stuck out. I bought a 3m from Amazon. The interface box is a tight tight fit and ended up mounting it in the lower glove box. Love having CarPlay! 2018 Telsa MS
Please do ![]() I’ve just ordered the same kit, at last! |
I recently fitted the Naviplus kit to my car with the Bosch screen, it may work with the iphone o.k but i tried it with android auto and it was Total Crap, it may well have been a bad kit, had several issues firstly the projected image was not even central in the screen and you could not use the control menu on the the right hand side side of the screen because it was not in the screen display area, it was so slow to work could have stopped for a tea break while it changed menus, plus if I had to touch the screen any harder to to get anything to move left to right or visa versa my finger would have gone through it. The screen works fine with the L/R installed software so there is no problem with the screen. As I say it might just be a bad kit or hopeless with the Android phones, hence it didn't stay installed for long.
Generally speaking we are really happy with our NaviPlus system.
Sorry for the delay in replying, I hand't checked to see if anyone was interested! So the Unique Audio Developments kit: ![]() ![]() Shipped it was £548. Came within 2 days. Installation was very straightforwards and the instructions super clear. First off, use the trim tool (included) to remove the HVAC panel. It was a bit stubborn and I had to use my existing trim tools to help lever it free. Once it's loose, unplug the three plugs from the rear. ![]() Then remove six torx bolts - two on the bottom of the screen and two on the bottom of each air vent. Remove each air vent. They simply pull out once the bolts are removed. ![]() Once the air vents are removed another two torx bolts will be revealed either side of the screen. Remove these. The screen sits in a cradle, lift it up and tilt forwards to bring it clear. ![]() Remove the plugs from the back of the screen and remove it completely. The wiring is very simple. The UAD box main wiring plugs into the back of the screen, and the grey connection from the car that was originally plugged into the screen plugs into the plug on the new wiring. The blue LCD plug from the car is left unplugged, and is replaced with the blue LCD out from the box. There is also an AUX connection, but I didn't use this as I wasn't sure what it was for. I have an AUX in in the armrest already. Finally there is a USB on the box for initial connection to your phone (and I assume for any updates to the box). ![]() On the box there are a series of 8 micro switches to be set according to whether you have Dual View (I don't think any L320s have this?) or an aftermarket or factory rear view camera. Check these are in the correct positions for your car. With everything connected up, turn on the ignition and test. Make sure to select reverse to make sure your rear view camera works correctly. ![]() If it all works, connect your Phone via the USB plug on the box, and set it up on your phone. Remove USB, cycle the ignition and test wirelessly. It can tale up to two minutes to connect - the instructions mention this. Sometimes it connects quicker. If you already have your car paired with your phone for Bluetooth streaming, DO NOT DELETE this connection. You should have another Bluetooth device listed as IDCORE (which is the UAD box). If everything works, it's time to put everything back together. Open the lower glovebox and press the hinges to lower it fully. I put my box right at the back, standing on it's end. It's the only place I could get it where it wouldn't interfere with the glovebox. I did actually remove the upper glovebox first but there's no room behind there. The UAD box is metal, so I wanted to keep it away from the fusebox on the left hand side. I sort of wedged it in on it's end, and tied the wiring around the metal support with zip ties. This will stop the box flopping out of position. It's a bit of a kludge, but it's the only way I could get it to fit. ![]() ![]() Make sure when putting the HVAC panel back that you have all the metal clips in place - otherwise it'll rattle. You need to use a trim tool on the underside of this panel to tuck the padding back under the top of the centre console trim. Et voila, working CarPlay. You lose the factory navigation (no great loss there!) and CarPlay is accessed by pressing NAV. All other media functions (DAB, TV etc) are retained. The steering wheel controls all work with CarPlay as well, including phone functions. I have made a short video showing it working, but I can't upload a video here? Total installation time was about two hours, and now its a couple of weeks later I'm very pleased. After fitting an Android head unit to my previous car (Audi TT) I was really missing CarPlay, and the recent toughening of the law regarding hands free usage of phones in cars really made me get this sorted (I'm not a fan of cradles and wires all over the place). Sometimes the audio can be a bit slow in connecting, which means having to rewind a podcast because the phone starts playing even though there's no sound coming out. But really that's a small annoyance compared to the convenience. |
