Home > General > Powerful uk roof rail system advice (fitting points?) L320
Page 3 of 3 <123
Shaun W
I’ve got the same set of rails waiting for a car to put them on, so following this with interest.
Did you have to cut the rubber trim down?
Post #617306 Wed Sep 15 2021 1:44pm
jases4x4
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Hi Shaun, There was no cutting, in the end Powerful uk sent me some bolts about 10mm shorter meaning i didnt have to use the spaces i was using but even then it wasnt tight enough so there was movement which is not good, The shorted bolts were spot on and i now have very tight secure rails and safe more importantly. They did say they have not had this issue before so the original screws they send might go fully into yours. Let us know on here if you dont mind it will be interesting to know and if you do have the same issue they know exactly what to send you.
This were the difference
I also pointed out this photo on land rovers identical set they have these spaces about 5/10m i think which they supply two of, Powerful send different spaces about
2mm so this difference could be the issue.
Post #617307 Wed Sep 15 2021 2:04pm
Shaun W
Still waiting to get my car, hopefully Friday. The screws/bolts look to be the ones you were sent th edits to time, so will e interesting.
Post #617503 Mon Sep 20 2021 9:21pm
jases4x4
Let us know shaun how you get on it will be interesting to know if mine was a one off and they fit yours perfect like every other customer 😃
Post #617511 Mon Sep 20 2021 11:05pm
Shaun W
Just tried to fit my rails, getting the plastic plugs out was a pain and I ended up having to drill 4 out as they snapped.
The screws are too long
So I’ve emailed them to ask for shorter screws.
Post #617690 Sat Sep 25 2021 5:14pm
jases4x4
Interesting Shaun, When company’s say you’re the only one to report this or have this problem, then the next person has exactly the same issue Shocked , Im sure its how businesses run these days, Good thing about Powerful uk though is they will fix it at there cost, Cant fault them for service and they know exactly the issue now and how to fix it. They’re basically missing that 5 mm steel washer imo, The picture i have posted above. The after market kit is identical to the Land rover rail system but with the missing washer, which powerful have replaced with 2 black plastic ones only 1mm thick which is not enough to tighten the rails down, resulting with them bouncing, Then the load been carried is unsafe.
Post #617691 Sat Sep 25 2021 5:28pm
Page 3 of 3 <123
