Home > General > Deafening squeal from brakes
Muddy90
United Kingdom 2006 Range Rover Sport Supercharged Tonga Green
As the title says - car is giving off a deafening squeal when moving. Jumped in it this morning and as I set off massive squeal from the brakes / wheels, so I didn’t even get off the drive. The squeal is from movement not braking.
Car has been sat for 2 weeks so I’m wondering if it’s anything to do with the heat / damp.
Had new discs, pads and callipers fitted about 1k miles ago. Hand brake is engaging / disengaging and holding the car on a slope when in neutral.
Any home remedies I can try before calling out a mobile mechanic?
Post #615249 Mon Jun 28 2021 7:34pm
Flyfisherman
Could try giving the callipers a tap with a hammer. Richard
Post #615253 Tue Jun 29 2021 1:37am
Lindab
Possibly a stone caught between back plate & disc Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e
Post #615258 Tue Jun 29 2021 9:16am
Brit Plumber
If its coming from the rear, I’ll bet my Sunday dinner on it being one of the handbrake shoes friction material breaking down. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #615357 Thu Jul 01 2021 4:19pm
Oldandconfused
B P may be on to something there, I had a bit of a rotational noise when setting off coming from the rear nearside wheel. On stripping it down I found that the pin holding the shoe to the backplate had rusted and failed causing the shoe to be pulled into contact with the drum. New shoes, pads and disks later all fine. I fitted a set of new slider pins as well for good measure, which were cheaper from LR than other places I tried.
Post #615363 Thu Jul 01 2021 6:36pm
