Home > Technical > Supercharger |
Hawk1262 Member Since: 22 Jun 2021 Location: Bristol Posts: 17 |
Hi
Fri Jun 25 2021 11:14pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
Certainly no rattle or noise coming from mine, I think one of the first things to do is check that there is actualy oil in it, not sure if it is actualy necessary to drain the oil when changing the snout but would have though it would be good practice to change it anyway if the supercharger has had repairs done to it, would not be the first time something has been drained and not refilled. Has it just developed or was It like it when the car was returned to you? also not sure if s/c needs to be removed to change the snout, do recall reading somewhere it is possible to change it without removing it on the sport but if it's in the 5.0L jag it has to be removed. If it has been removed make sure they have refitted the insulators shield to the inlet manifolds as I believe these help prevent noise, vibration and harshness etc. Will admit though however not sure how they actualy attach.
Sat Jun 26 2021 5:35am |
Thanks for the reply, yes I was told by landrover that the whole supercharger was removed as could not get the get the end off. I did notice is was a little nosiy when I check my water on my washers a day or so after, but after I had restricted performance problem I notice the nosie had got louder it has only done 500 miles since repair. do you know how to check to see if oil is in the supercharger? Thanks again |
Sat Jun 26 2021 5:43am |
There is a filler/level plug at the rear of the S/C however wouldn't really know how accessible it is or how much room between the S/C and bulkhead, may be able to use a mirror to locate/see it.
Sat Jun 26 2021 12:27pm |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
maybe what he shows below? the coupler does die sometimes.
Sun Jun 27 2021 12:27pm |
If it's had a new front end snout fitted by L/R 500mls ago you would like to think they fitted a new coupling then, as it is included with the new snout kit, or it is at least in genuine L/R kit's.
Sun Jun 27 2021 10:20pm |
Thanks for the replys. As far as the dealer cares that any work done by them is not they problem I would not trust them at all now after speaking to them. Would not except any work that has been done has caused The problem & any car over 7 years old will have problems no matter what work has been done by them. |
Sun Jun 27 2021 11:51pm |
Why was the Snout replaced in the first place? I assume because the shaft/bearings were noisy or worn, or the coupling and torsion spring were worn or broken which was a issue in the early days.
Mon Jun 28 2021 12:40am |
Was told the snort had play in it which was causing my misfire on tickover, after parting with £1300 still have the misfire & now a supercharger worse then before it was so called repaired. So have no faith in anything Guy salmon Land Rover Bristol tell me |
Mon Jun 28 2021 7:30am |
No expert obviously, but seeing as the snout is simply the mechanical shaft drive between the S/C belt and the s/c rotors I see no logical connection in play in that component and a engine misfire it's not as if its some kind of electrical distributor like the old day's. There is a TSB with reference to worn coupling, broken torsion spring, excessive backlash etc. and certainly no mention of a engine misfire as a being a symptom of any of any of those faults.
Mon Jun 28 2021 7:50am |
Gotta agree with Col here.
Mon Jun 28 2021 8:14am |
Codes coming up are
Mon Jun 28 2021 9:13am |
Since its only 1 cylinder. I'd hazard a guess at valve clearances now. Does this engine use buckets like the 4.2?
Mon Jun 28 2021 10:09am |
Now going into garage to be checked out not sending it to the dealer as can't be trusted. Will update when garage give a report. |
Thu Jul 01 2021 6:45am |
