Home > Technical > RR 2.7 TDV6 rocker cover gasket leak
evets
Oil leak on 2.7 TDV6 rocker cover drivers side.
Replaced camshaft and secondary timing chain on exhaust drivers side. car starts fine
Had an oil leak so replaced rocker cover and gasket on car it is still leaking oil any ideas?
Post #614530 Tue Jun 08 2021 8:38pm
Seam too common as issue.
Don’t know why these cam covers leak
Post #614548 Wed Jun 09 2021 9:02am
Brit Plumber
I can’t comment on that particular engine, but common reasons for leaks are damage, over tightening, ware, over pressure (liquid can’t drain away quick enough) and incorrect part/application or fitting. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #614582 Wed Jun 09 2021 2:50pm
