Home > Faults & Fixes > AC fault |
Ian RRS Member Since: 06 Jun 2021 Location: West Midlands Posts: 3 |
Hi everyone, last year my 2014 RRS AC system didn’t seem to blow as cold as it should, I took it to have refrigerant topped up, it turned out that it was low but not by too much. Within a few weeks I noticed a mist coming through the centre cabin air vents and since then no cold air at all. Before I spend out just wondering if anyone has experienced anything similar. Thanks in advance |
Sun Jun 06 2021 7:24am |
Thanks, do you know the location of the condenser? The garage who topped up the refrigerant are only any good at regassing, when it comes to issues they are far from specialists |
Sun Jun 06 2021 3:09pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849 |
This may help,
Sun Jun 06 2021 7:59pm |
Thanks for the information, my RRS is the 2015 model, not sure if it’s the same as the older models? |
Mon Jun 07 2021 7:14am |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 948 |
Mon Jun 07 2021 10:44am |
Sorry missed that bit, try you tube for your year. The positioning on all vehicles is similar, it’s just the difficulty in getting to it which varies. Like I said though, before you throw a ton of cash at it and find it’s not the condenser but a pipe to it, put some dye in the system. You may just find it’s a dry seal! 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Mon Jun 07 2021 4:47pm |
