Home > In Car Electronics > reversing cam |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
well, the problem with number plate cam's, is getting the cable from the light to the top of the tail gate.
Sat Jun 05 2021 9:29pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1052 |
As Andy says, not that easy to get wire out of the split tailgate. Mine is hidden under trim as much as possible then black duck tape where it is exposed does the trick and is not visible. Then, again as Andy says, in the headlining through to the front passenger A pillar. |
Sun Jun 06 2021 5:47am |
jk3528 Member Since: 30 May 2021 Location: stoke on trent Posts: 73 |
Thanks looks like fun |
Sun Jun 06 2021 7:04am |
What year is your car and what you connecting it to |
Sun Jun 06 2021 8:59am |
It’s a 2006 hopefully into the screen as I think it’s the same one as my D3 but just got to work out how to get at it? |
Mon Jun 07 2021 9:38am |
Oh do the RR mod ?
Mon Jun 07 2021 10:35am |
Tue Jun 08 2021 8:50am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4972 |
You need something like this a RCA to Fakra adapter cable, plenty on Amazon.
Tue Jun 08 2021 9:34am |
yeap.
Tue Jun 08 2021 9:43am |
Ordered is it the yellow wire in the plug that’s in the back ?
Tue Jun 08 2021 11:47am |
It’s best to power the cam off the rear power socket or the Ariel amp blue wire in the rear roof side.
Tue Jun 08 2021 1:58pm |
See wire cutting inside here
Tue Jun 08 2021 2:02pm |
cassman Member Since: 09 Nov 2020 Location: Essex Posts: 66 |
If the Brown connector is for the reverse camera
Green TV
Tue Jun 08 2021 2:04pm |
