Home > In Car Electronics > Sat Nav GPS Fault
RJR5011
Sat Nav GPS Fault
Hi looking for help with Sat Nav and if antenna fault or dvd disc?
Sat Nav works but it’s location is often miles out and thinks the car is elsewhere than where it is in reality making it pretty useless.
I think antenna fault and happy to spend £100 plus to change but wondered if common fault and maybe something else like the DVD player / disc needs an upgrade
Why I think it’s the antenna is the Bluetooth has also failed and thought the two are connected
Richard
Post #613757 Tue May 18 2021 1:49pm
people have used £10 ones off ebay.
That would have a cheaper way if you are unsure it's faulty
Otherwise, check the map is set to UK
https://www.rrsport.co.uk/forum/topic32826-30.html
Post #613761 Tue May 18 2021 3:44pm
RJR5011
Thanks will do and yes map is UK Thumbs Up
Post #613768 Tue May 18 2021 6:52pm
