Home > Technical > MY12 touch screen no "Extra features" option
sjm
Hi,
Even though the handbook indicates I should have the "extra features" button, my screen does not show it. It's not greyed out it just isn't there.
I know in the past the screen has been replaced but other than the "extra features" missing it looks standard. what is slightly different is that I have the option for 3 pre-set items instead of the usual 2 and the top left button says setup instead of audio features. The latter is apparently what you get if you have dual view but it isn't a dual view screen
is this something to do with how the screen was configured when it was replaced or because there are no extra features enabled?
I don't even have access to the 4x4 information never mind the climate control or whatever else might be in the extra features.
Is this something we can fix/setup ourselves (we have a nanoom) or something that a LR independent could sort for me? it is going in for a cambelt this week so I could ask them to look at it for me then.
thanks
Post #613480 Mon May 10 2021 1:32pm
I do have a dual view and the top left button say's setup, are you sure you don't have a dual view screen fitted to a vehicle that never had dual view factory fitted? I thought the setup button on a standard view screen was located buy the rotary mode switch to the right of the clock, which is where my dual view button is, hence why setup is on the screen instead.
Post #613482 Mon May 10 2021 1:59pm
sjm
Hi Col,
It is possible as I think the My12 HSe the dual view was an option. Would that be why I don't have the "extra features" button as well?
thanks
Post #613483 Mon May 10 2021 2:04pm
Not sure why you don't have extra features button as that is where the 4x4 info is located on mine along with the surround camera system on mine. Don't recall seeing anything in the ccf files to re-configure the screen but to be fair have never looked, perhaps it needs some sort of software update.
Post #613484 Mon May 10 2021 2:11pm
Brit Plumber
Can your nanocom pull the VIN from the screen? I suspect if it can, it won’t match your car and will be a donor part. I did have the same problem with one of my screens, and I even checked the 4x4 setting was switched on in the CCF but the only way to fix it was to replace the unit. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #613585 Thu May 13 2021 7:09am
Brit Plumber
Measure the diagonal distance of the screen only and tell us what it is. A DV screen is smaller than a standard screen and I think only half of it would work in a standard car. 2019 5.0 SC SVA (Current)
Post #613586 Thu May 13 2021 7:12am
sjm
Hi Brit Plumber, thanks for the reply.
I will check when it is back from the garage...a planned visit to do the cam belt Smile
Post #613588 Thu May 13 2021 8:22am
