![]() | Home > General (L494) > How to turn off keyless entry |
ThickSole Member Since: 10 Mar 2023 Location: UK Posts: 1 ![]() |
Can turning off keyless entry be bypassed? It turns off the system within the car, but my question is does it actually turn off the signal being emitted from the key fob? And if not, can that be turned off?
Mike London Member Since: 22 Jul 2014 Location: Cotswolds Posts: 56 ![]() |
I’m not convinced that turning off keyless entry is a security upgrade because if you have to use the buttons on the fob the signal can be intercepted whereas there is a much shorter signal being emitted when you just use the handle and the relay risk is removed if you keep your keys in a faraday pouch.
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 247 ![]() ![]() ![]() |
Yes the signal can be intercepted and then used but only when you press the button so they would have to be close and sat waiting, Unless its the same time of day you set off or come home then they would have to be close, Or when locking going into supermarkets, I hear some sit in carparks reading signals for when someone presses fob, Once in they still need to plug into obd port with device if keyless is switched off so have a lock of some sort over the obd aswell so if they get into car theres too much time required to access obd port. |
Gumby Member Since: 04 Apr 2021 Location: London Posts: 12 ![]() ![]() ![]() |
I tried to to this last year - MY2012 L320 wasn't playing ball either. Same as RugHead, Patrick at GAP played a blinder and helped to sort it. It was just an update needed to the KVM-Wireless module thought the IID Tool. Once done, keyless entry could be disabled. Takes a bit of getting used to, especially when you're carrying a bunch of stuff over to the car! |
Iguana Member Since: 03 Feb 2024 Location: Somerset Posts: 26 ![]() ![]() |
There's resurrection |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
I have often wondered if this is actually of benefit as well, if you just use the door handle /buttons the fob has to within around a meter of the car to work, if you use the fob buttons you can unlock/lock the car from up to twenty odd meters away, which is when it's easy to intercept the signal I guess. So if you just use the handle/button they would need to be stood virtually next to you to intercept it, unless the fob is continually emitting a signal all the time they can intercept when not in use of course. With the OBD port just fit a dummy one and wire straight to earth so as soon as they plug in their device it fries it. ![]() Cheers Col |
