![]() | Home > In Car Electronics > Help please no sound |
Mafya Member Since: 05 May 2020 Location: Sheffield Posts: 46 ![]() ![]() ![]() |
I’ve had this happen to me a couple of times so I have switched car off and locked it using my fob as I have keyless entry and then 30 minutes later got in and it’s all back working again. |
Leechicken74 Member Since: 09 Nov 2020 Location: Kent Posts: 59 ![]() ![]() ![]() |
This has happened to me on the odd occasion and a turn off and leave for 10 minutes has worked, but if not then its likely to be the main AMP that's not working, you will find it under the drivers seat and it may be faulty or it could be a simple power supply/fuse issue. If you search the forum there is a number of threads on the amplifiers. Lee
Kot Member Since: 07 Jan 2021 Location: UK Posts: 92 ![]() |
So what was the fix?
Atlanticjon Member Since: 22 Apr 2015 Location: Coleraine Posts: 42 ![]() ![]() |
I seem to have much the same issue on 2019 autobiography with meridian audio.no audio on any source or on the phone.
Atlanticjon
Decided to disconnect the battery, after struggling with the spare wheel, took off the negative terminal for 5 mins heard a relay going off . Reconnected and hey presto, we have sound.... so maybe try this as a quick fix. Read an American website that surmised if you had a low battery the amp didn't switch off properly and thus wouldn't switch on again.... |
It was the Amp Module that was frozen, solution was to remove Fuselink to reset system and update module.
