Home > Technical > Egr delete 3.0 tdv6
Benjamink92
Norway 2011 Range Rover Sport 3.0 TDV6 HSE Orkney Grey
Egr delete 3.0 tdv6
Hi, I have a rrs 2011-2012 3.0 tdv6 245hp.
I want to blank of the egr system. On these models, is it enough to enter the software and disable the system? Or do I need blanking plates also? Is there anything else needed to do then disabling the system? Regards Benjamin
Post #612124 Tue Mar 30 2021 9:09pm
cassman
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
If you blank off the EGR isn't that an MOT failure? Current car - 2016 MY17 L494 in black - sometimes towing a Buccaneer Cruiser.
Sadly gone - 2013 L320 3.0 TD in grey! sometimes towing a Buccaneer Cruiser.
Post #612148 Wed Mar 31 2021 3:38pm
1richard1
Only if its been picked up as being blanked off.
Post #612150 Wed Mar 31 2021 4:30pm
Disco_Mikey
Also affects DPF regenerations
Thankfully, the 3.0 EGRs rarely suffer from failure
Post #612156 Wed Mar 31 2021 6:06pm
Lancs_RR
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Lux Stornoway Grey
Hi
Did you ever do this?
Any notable benefits /drawbacks?
Genuine curiosity.
Post #617212 Sun Sep 12 2021 7:40pm
