Home > Faults & Fixes > Roller Parcel Shelf a little limp. |
Fantom Sport Member Since: 27 Feb 2021 Location: Surfleet Posts: 8 |
Ok, managed to fix myself, very simple, undo the torx screw on one side and pull the end cap off. Pull the opposite end cap out just enough to turn it, wind it around a few times and push it back in. Replace the original end cap, it takes a little wiggling. Replace screw and job done. They only doubt I have is that only one side has tension on spring but it appears to work. |
Sat Mar 27 2021 1:51pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Good job and thanks for the explanation, as these get on I’m sure we’ll go looking for info. 2006 2.7 TDV6 HSE in Cairns Blue. |
Sun Mar 28 2021 6:52am |
stevef1964 Member Since: 16 Aug 2016 Location: Surrey Posts: 2 |
Cheers for the info. Just done mine. |
Thu Jun 17 2021 1:39pm |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 314 |
Useful info thanks for that. When I read the title I thought it said your parcel shelf had gone into limp mode 🤪 Steve
Thu Jun 17 2021 5:54pm |
