![]() | Home > In Car Electronics > Sat nav update |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
no and no.. |
Kitchenfitter Member Since: 20 Feb 2021 Location: CV61AH Posts: 352 ![]() ![]() |
Well that answers my questions lol
RugHead Member Since: 26 Nov 2020 Location: South Yorkshire Posts: 40 ![]() ![]() ![]() |
If your system is the Gen 2.1
Thank you have you done this and if so how easy is it
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5122 ![]() ![]() ![]() |
If your car is on a 62 plate it will certainly be Gen. 2.1 if you want know the current map version installed you will need to go into the "hidden menu" it also takes around over 2-2.5 hour to update map.
Thank you all received 👍 |
Gumby Member Since: 04 Apr 2021 Location: London Posts: 12 ![]() ![]() ![]() |
Out of curiosity - did you manage to do this in the end? Was it relatively easy/worthwhile, or is it better to just stick with the various mobile apps? |
cassman Member Since: 09 Nov 2020 Location: Essex Posts: 71 ![]() ![]() ![]() |
I did it on mine,
Is it bestvto down load or have it posted ? |
I did the download and expand it onto a USB stick. Current car - 2016 MY17 L494 in black - sometimes towing a Buccaneer Cruiser.
I have psid a little extra to have it sent on a usb stick so hopefully all will be wrll |
Bertbuckie Member Since: 04 May 2021 Location: Scotland Posts: 274 ![]() ![]() ![]() |
I just did this....
Will have a look 👍 |
