Home > Technical > Rear prop orientation
Fire1
I’ve replaced rear prop and I’m sure I’ve seen a few times about a certain way to fit it although when I look I can’t find anything solid.
Does anyone know is there a certain way to fit the prop back on the car?
Or does this only apply when you split the prop to change the centre bearing putting the 2 halves back together?
TIA.
Post #611009 Fri Mar 05 2021 11:14am
It’s sometime sensible to mark where an old one came off to rule out problem.
But don’t worry about it
Post #611012 Fri Mar 05 2021 12:13pm
