Home > Maintenance & Modifications > Just fitted 30mm rear spacers ๐Ÿ˜
DwylieRRS
England 2013 Range Rover Sport 3.0 TDV6 HSE Fuji White
So been debating what size spacers to get to fill out the arches finally decided on rear 30mm and front 20mm rears arrived sat so fitted straight away and what a difference it makes looks so much better Iโ€™ve only had the car 2 weeks so far fitted side steps for the kids full black pack inc 2018 SVR front grill and now spacers il starch couple before and after pics the 1st pic is b4 the rest are after
Post #610452 Tue Feb 23 2021 2:35pm
Buckster
Does it not drive weird now? Thought spacers the same width should only be used front and rear to make the track the same as it would have been without spacers? 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18โ€ Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning ๐Ÿ˜Ž
Post #610471 Tue Feb 23 2021 6:08pm
That looks like it'll rub the wheel arch rim if the suspension gets compressed. 2012 SDV6 - it's missing a couple of cylinders
Post #610493 Tue Feb 23 2021 10:14pm
DwylieRRS
No a lot of cars will run dif sizes front to rear depending on look but no drives excactly the same Iโ€™ve been told but quite people that l494 should run rear 30mm and front either 20 or 25mm front max Also i think they look wider in the pics thereโ€™s still plenty of space for it not to rub as standard the space is huge .
Post #610597 Thu Feb 25 2021 7:50pm
