Home > General (L494) > Retofit Fail on RRS MY16 HSE |
machintruck Member Since: 12 Aug 2020 Location: Perpignant Posts: 9 |
Hi at all,
Fri Feb 05 2021 2:50pm |
SC247 Member Since: 15 Oct 2019 Location: Staffs Posts: 60 |
Hi
Sun Feb 07 2021 12:02pm |
Heremyjill Member Since: 01 Jun 2020 Location: Shrewsbury Posts: 89 |
Claude,
Sun Feb 07 2021 4:52pm |
Thank you for your messages.
Sun Feb 07 2021 8:44pm |
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 409 |
This is the correct switch for the 2014 2015 model, the repalcement swithc needs to look similar to the one you remove namely the buttons on the earlier models are horizontal and the newer style are vertical and smaller If a jobs worth doing, get a someone who knows what they are doing to do it! RRS Autobiography Indus RR P38 HSE V8 RRS Supercharged Santorini AMG CLK Rear Tyre Shredder |
Tue Feb 09 2021 8:54am |
The system will work without the need of the physical switch (its just a quick convenience) when I got mine working I didnt have the switch and it all worked, the switch is essentially dumb if its not there then the car doesnt care.
Tue Feb 09 2021 9:36am |
Thank you for all these explanations and for your help.
Sat Feb 13 2021 6:10pm |
Im not overly sure what any of that means, however at a guess you are trying to calibrate the forward facing camer in the mirror?
Sat Feb 13 2021 6:28pm |
I believe that if you have a new windscreen this calibration needs to be carried out, try asking a auto windscreen company if they can do this for you. |
Sun Feb 14 2021 7:50am |
Claude
Tue Feb 16 2021 2:54pm |
Good spot I think the AA on the mirror part means is was just AHBA and not the GC verison of the mirror hence the car doesnt seem to see the new mirror in the SDD ecu list, the camera mirror you bought is the correct one but its not being picked up as being present in the software.
Tue Feb 16 2021 3:45pm |
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 |
Hi, did your car have the 3 wires or the 7? I have the switch with the LDW switch on and it seems to have a bigger connector on it (like the one with 7 wires but the car has the small connector with 3 wires, it will fit but doesn't operate the boot, does it need programming for the boot switch to work? 2016 Black SDV8 Autobiography 2013 Grey Black Edition SDV6 (lasted a while but gone now) 2005 Grey Supercharged Sport (gone but never forgotten) |
Wed Feb 24 2021 9:10pm |
Mine is a 2014 and uses the single connection which is the smaller of the 2 connectors, like item 1 in the image (that is my image the top one is the original swtich that came out fo the car, the seocnd one is the one I needed, and the third one is the first one I bought that didnt work as my car only had a single lead/connector in the dash board)
Thu Feb 25 2021 10:33am |
I have the newer switch as you suggested and the green plug fits and works correctly, the grey plug has three wires in it and is small than the hole for it on the new switch, it will plug in but the boot doesn't operate from the switch! 2016 Black SDV8 Autobiography
Thu Feb 25 2021 1:39pm |
