Home > Faults & Fixes > HELP A.S.A.P Car at workshop! |
amgmaj Member Since: 28 Nov 2017 Location: Nottingham Posts: 79 |
Try this mate it worked for many
Tue Jan 19 2021 11:50am |
Niclas79 Member Since: 17 Jan 2021 Location: SkellefteƄ Posts: 5 |
Now the mechanic have called and they cant find any fault, no codes etc but the car starts when they have it in the warm garage. What Will I do?
Tue Jan 19 2021 12:58pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8974 |
Sounds like a glow plug issue. One or more isn't working properly so the engine won't start when very cold. Either test/replace the glow plugs or fit a timer to the Fuel Burning Heater so that it runs for a while before you need to drive. Also results in warm air as soon as you get in. 2012 SDV6 - it's missing a couple of cylinders
Tue Jan 19 2021 4:17pm |
Called land rover and they tought it would be the main fuel pump under the Hood.
Tue Jan 19 2021 10:56pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
I assume they have checked the glow plug fuses and relays, should be two of each, one for L/H bank and one for R/H bank in the engine bay fuse box.
Tue Jan 19 2021 11:43pm |
