![]() | Home > Wheels & Tyres > Tyre pressure for larger profile tyre |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
I use 35 front and 38 psi at the rear with cold tires. a 40 or 45 tire does not make any difference. Tire wear is very even. A good wheel alignment is pivotal though and make sure that your measurement (gauge) is sound.
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 ![]() ![]() |
Hi,
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 ![]() ![]() ![]() |
36 rear & 33 front are OK for the Pirelli All Season tyres as they have stiff sidewalls, however for your Michelins I would use as already suggested 38 rear & 35 front.
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
Thanks folks,
The truth is, the same pressure applies to tyres whatever the aspect ratio, it is pressure after all, not volume.
Leechicken74 Member Since: 09 Nov 2020 Location: Kent Posts: 59 ![]() ![]() ![]() |
Does the 36/33 setting apply the same for the TDV8 as it’s heavier? I’m sure mine is 38/36 at the moment on Pirelli all season, so may need to adjust them, it does feel a little harsh at times Lee
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
Always ran both my old TDV8 and 5.0L S/C at 33 front 36 rear with 45 profile Pirelli all season on both 20 & 21" rims, personally found ride and handling fine with no undue wear.
Lee
Excellent Thanks Dave and Col Lee
Sham91 Member Since: 24 May 2018 Location: Bradford Posts: 178 ![]() ![]() ![]() |
I use 40psi all round 255/55/20 :/ RRS TDV6 2010 |
