![]() | Home > Technical > Centre Console Bezel |
abiopete Member Since: 27 Feb 2020 Location: Manchester, UK Posts: 169 ![]() ![]() ![]() |
Hi all, has anyone changed one of these before? Does the console have to come out or does it just unclip? I have tried unclipping it but don't want to apply too much force in case something breaks!
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
You have to remove the console part first as it is also retained by two screws underneath as well as some clips, you can see where the screws are fitted by the two lugs in the picture at the end by the range rover lettering.
