![]() | Home > Technical > 4.2 SC. Transmission clunk after fluid and filter change |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
Welcome Muddy90,
Muddy90 Member Since: 09 Jan 2021 Location: Cardiff Posts: 9 ![]() ![]() ![]() |
Thanks for the welcome
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
They've reset the gearbox adaptive so the gearbox is now having to re-learn how worn it is. It will improve as the ECU adjusts for the wear.
Thanks RRSTDV8 - that sounds more promising. The thought of potential transmission damage had me feeling quite queasy all week!
I'd drive it gently for 100 miles and hopefully the gearbox will figure itself out and be smooth again. 2012 SDV6 - it's missing a couple of cylinders
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 782 ![]() ![]() ![]() |
Hi there, stick around, it's a mine of information |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5036 ![]() ![]() ![]() |
Cigar lighter not working ?
