Home > Technical > Radio Interference
Ade99
United Kingdom 2008 Range Rover Sport TDV8 HSE Izmir Blue
Radio Interference
Hi all and Merry Christmas
Its been a while since I have posted my08 tdv8 has a problem with the radio.
It only started last week if i have the radio on everything is fine but as soon as i turn on the heated rear screen i get interference through the speakers. Have checked all other switches as well but it is only the rear one that causes this problem.
Has anyone got any ideas what might be causing this?
Cheers Ade Big Cry
Post #607899 Sun Dec 27 2020 4:00pm
Smarttech
I have a 17 plate svr which does exactly the same. Radio is as clear as can be then I press the button for the heated rear screen and it sounds like it's one digit out of tune. Turn the rear screen off and clear again. I've not done anything about it as 99.9% of the time I use Apple car play so never listen to the radio but suppose I should while it's still under warranty 2017 SVR. SVO Scafell grey Ebony interior
2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior. Gone
Post #607902 Sun Dec 27 2020 10:26pm
Ade99
Thanks for the reply Smarttech i did here that there was an update on new models.
I have checked the fuses and some of the earthpoints in the rear end next job i think is to drop the headlining at the back and check there.
Post #608037 Thu Dec 31 2020 5:08pm
Smarttech
Hope you find the problem mate. I just don't use the radio enough to worry about it so will just leave mine unless Landrover want to fix it under warranty but then after the shocking service they gave last time I went to the dealer, I'm not sure I want them touching my car again. 2017 SVR. SVO Scafell grey Ebony interior
Post #608056 Fri Jan 01 2021 9:08am
