Home > General (L494) > Hardwire Rear Screens and LED's ?
CrissyCriss
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Anyone know the best method to hardwiring rear entertainment screens and also LED's? Can these go to a fuze box? if so which fuse box is recommended?
Post #607595 Thu Dec 17 2020 12:53pm
akalair
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Hi, I have some genuine rear entertainment headrests for sale if interested. Minus the screens, but can be fitted with aftermarket screens whilst retaining OEM look.
The are brand new in grey.
Thanks
Post #607697 Sun Dec 20 2020 9:59am
pjbracer1
https://www.ebay.co.uk/itm/GENUINE-Land-Ro...Swpk9f3OSA
I'd mod these and use some old ipads or droids whic ever flicks ur switch, the screen will be bigger and removeable, also if you installed a mifi somewere in the car then they woould connect to that, you could go one better and set up a mini plex server on another mini pc or something and hide it in the boot, and then use a usb key to store the librabry on so each side could select what they want.
You can also remote control andriod using zoho so if you had the app on your phone you could set up a film remotely on each tablet, with plex if you start a film on one device you can pick up where you left off on the other device, benefit of tablets is ou could use netflix if 4g signal is good on the move just keep some bt head phones for each side liek the factory fit ones If a jobs worth doing, get a someone who knows what they are doing to do it!
RRS Autobiography Indus
RR P38 HSE V8
RRS Supercharged Santorini
AMG CLK Rear Tyre Shredder
Post #607850 Thu Dec 24 2020 5:26pm
