Home > Technical > RRS 2010 TDV8 Xenon leveling problem
Jackharrer
Poland 2010 Range Rover Sport TDV8 HSE Santorini Black
Hi
I suspect that my RRS has no automatic leveling system ( Valeo AFS Headlights ) . At start up xenon "dance" is only very little horizontal movement and zero vertical movement. Can anyone check this in his 2010 RRS?
I also find following photo on one of a polish lighting tuner website. Guy is surprised that there is any hight adjustment motor inside RRS lamp...
Post #607390 Thu Dec 10 2020 2:02pm
Do you not have a label similar to this on top of headlamp unit?, should tell you which type of lamp you have.
Post #607395 Thu Dec 10 2020 8:39pm
To the polish guy. These have air suspension so it doesn’t need vertical adjustment
Post #607396 Thu Dec 10 2020 8:57pm
I think the AFS does adjust the h/lamp vertically based on speed of vehicle, don't know if it is the same motor used by the self levelling of the air suspension in some way though, although I think I could be getting the horizontal and vertical aspects of the AFS muddled up.
Post #607398 Thu Dec 10 2020 9:22pm
Jackharrer
Yes I have a similar sticker ( Valeo AFS cornering EU SPEC ).
I also have L322 and although it has an air suspension it also has xenon leveling as well as many other cars.
Probably all RRRS with Valeo Headlamps do not have auto leveling because they don't even have motor inside the lamp.
Maybe someone can confirm that? The easiest way is to check if light goes up and down on start up.
Regards
Post #607405 Fri Dec 11 2020 7:35am
