Home > My Range Rover Sport > Heater temp
Plazmapete
Heater temp
Rolling Eyes 2006 range rover sport my heater is blowing hot from drivers side but only warm from passengers side. Also getting low coolant but plenty in the expansion tank. Could it be an air lock??? New alternator.
Gearbox flush.
Post #607246 Sun Dec 06 2020 12:19pm
Coolant tank replacement is common on these to stop the warning message.
The float inside sticks. £25
Could be a blocked heater matrix causing lack of heat
Post #607247 Sun Dec 06 2020 12:31pm
Plazmapete
How do you unblock it ?
Does it involve taking the car apart ?? New alternator.
Gearbox flush.
Post #607264 Sun Dec 06 2020 10:45pm
it can be attempted under the bonnet, by disconnecting the small water pipes on the drivers side, and stuffing a hose pipe into the end.
If that fail, matrix need changing
Post #607275 Mon Dec 07 2020 1:24pm
Disco_Mikey
New matrix required. You won't unblock it unless your extremely lucky, or patient Laughing
Post #607291 Mon Dec 07 2020 7:40pm
1richard1
Go to a refrigeration suppliers and by a gallow gun and a pack cartridges, be careful as they apply a lot of pressure fast if it can be unblocked that will shift it, were glasses/googles as if something comes out it will be coming out fast.
Post #607293 Mon Dec 07 2020 8:34pm
