![]() | Home > In Car Electronics > 2012 RRS interior roof lights not working... |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
I still think you need to check Fuse 57 (10amp) in fuse box behind passenger side glove box. The other circuits are controlled by FET's.
Grey Member Since: 29 Nov 2020 Location: Bury St Edmunds Posts: 5 ![]() ![]() ![]() |
Will do I'll double check it tomorrow it was a right pain to get to in the first place after attempting to take it out. There was some sort of live feed just above it. Anyway I'll remove and inspect. 👍 |
Always found a pair of long tapered nose pliers ideal to pull the fuses, that stupid tool in the fuse box is as much use as a chocolate teapot unless you have fingers like ET.
Would like to thank you for suggesting the fuse. Took it out and it was blown. Replaced it so all is working. However the OSR one isn't because of it being unplugged and no way of connecting it again lol. |
When the map lights were fitted at the factory, they fitted them to the lining before fitting the lining to the car. The loom was fitted at the same time as the lights and the loom was glued in place. It sounds like you have the same problem I had on my 12MY and I had to slide my hand up from the C pillar, over the lining and pull the glue off which gave me the extra length. 2019 5.0 SC SVA (Current)
