![]() | Home > Technical > Webasto heater advice |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 ![]() ![]() |
Hi
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 314 ![]() ![]() ![]() |
Mine only kicks in on startup if the ambient temperature is below 5 degrees as per handbook. Steve
Demaske1 Member Since: 17 Oct 2018 Location: Cheshire Posts: 26 ![]() ![]() ![]() |
Hi, I thought that was the case but when I turn the blowers off to the cab the webasto goes off and when I turn the blowers on it comes on again. I had already left the engine running for 15 mins and temperature gauge was just over a quarter of the way from cold. I’m just checking this is the way it’s supposed to be. |
I’ve never played with the fan switch when mines running to honest, got some cold weather coming though. Steve
Hi,
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 ![]() ![]() ![]() |
The FBH on my Disco with the SDV6 engine will run when the engine is running until the operating temperature has stabilised at 'normal', whereas the FBH in my RRS with the TDV8 will shut down as soon as the gauge is halfway to 'normal'.
