Home > Technical > DEF (AdBlue) injector wiring
RRSporter
Had the dreaded no restarts in xxx miles etc. Had faults read so far suggesting NOx sensor. However also have P2047-13 suggesting open circuit to DEF injector.
Before my (good) Indy who hasn’t seen this fault before opens an expensive sensor I’d like to take a look under the heat shielding of the wiring to said DEF sensor.
Different engine but same issue here linked below.
https://autotechnician.co.uk/ask-harry-injector-wiring-fault/
I’m assuming access from removing the engine or transmission guard tray? Any advice please as to how to locate?
Cheers 3.0 SDV6 HSE L494
Post #606261 Thu Nov 05 2020 8:38am
RRSporter
Ok this must have been obscure as nobody was able to help. I’ve sorted it all out today luckily at minimal expense. Broken wire to DEF injector. Simple fix. Carry on trucking 👍🏼 3.0 SDV6 HSE L494
Post #606338 Fri Nov 06 2020 7:19pm
