Home > General > Powered tailgate spring clips
Phil23
United Kingdom 2013 Range Rover Sport SDV6 HSE Java Black
Afternoon All. Following on from my tailgate issue post. I have a 2013 L320 with a one piece powered tailgate. Strut came off the upper ball joint, drivers side. The spring clip is still there, it does go back on but is popping every now and then. There is nothing wrong with the strut and I can get replacement ball joints. Does anyone know where I can get the spring clips from?.
Also, every now and then I have started to get a tailgate open indication. It's not open, but I have to open and close to clear the warning. An electrical issue?.
Many thanks.
Post #604733 Mon Sep 21 2020 6:01pm
Matt preece
United Kingdom 2013 Range Rover Sport SDV6 HSE Fuji White
Mine has been doing the same thing for a while , what i did was get some good quality cable ties and attach the strut to the ball joint its worked for me not come off for months
Post #604750 Tue Sep 22 2020 10:17am
Phil23
Cool. That'll certainly make for a good temporary fix. Cheers.
Post #604751 Tue Sep 22 2020 10:35am
Silverstone
United Kingdom 2012 Range Rover Sport Supercharged HSE Baltic Blue
I think that the problem you will find is that once the strut has come off once it will have slightly bent stem of the ball that attaches to the tailgate in the process. Hence it does not sit square next time you re-seat it and will keep popping off. I found this and only changing the screw-in balls will fix it. There is no replacement for displacement - W O Bentley
MY2013 5.0 Supercharged HSE L320
Post #604752 Tue Sep 22 2020 10:44am
You might have to buy a couple of the individual plastic type ball joints to get the clips as never seen them advertised seperate, various joints on fleabay for a couple of quid each, problem might be working out the size you need. L/R do the ball seperate but don't list the clip seperate it comes as part of the strut.
Post #604755 Tue Sep 22 2020 10:49am
