Home > Maintenance & Modifications > Independents in West Sussex/Hampshire/Surrey Border
SuperC
United Kingdom 2012 Range Rover Sport Supercharged Zermatt Silver
Hi All,
Can anyone recommend a good independent service place in West Sussex/Hampshire/Surrey border area? I'm looking to get brakes fitted all-round. I'm thinking an upgrade to EBC slotted and dimpled discs with EBC Greenstuff. Good idea or stick with OEM?
Cheers,
Stuart. Cheers,
Stuart.
RRS 2012 HSE 5.0 S/C Zermatt Silver.
RRS 2005 4.2 S/C First Edition Rimini Red- Gone but not forgotten
Defender 2005 TD5 XS Black - Gone
Freelander 2006 HSE Blue - Gone
Post #604433 Fri Sep 11 2020 10:12am
Dave B
Slotted and dimpled discs, might look good (depending of your point of view), but will not improve braking in any way whatsoever, however they will increase dust for your wheels to look a mess in next to no time.
Brembo high carbon discs all day and every day for me, and unless you go for ceramic low dust items, Brembo pads as well.
Dave @ R&G Autocare in Lancing is worth a shout, 01903 764423, tell him DBT Dave gave you his number.
Dave
Just seen you want an indie higher up than the south coast, sorry can't help there. 2010 3.6 TDV8 HSE (Gone)
Post #604434 Fri Sep 11 2020 10:29am
SuperC
Thanks Dave. Lancing is a bit of a travel but, thanks for the advice on the Brembo's. I'm going to give them a call anyway as I'm often down that way.
Cheers,
Stuart. Cheers,
Stuart.
Post #604436 Fri Sep 11 2020 11:00am
Wouldn't bother with brembo pads on a S/C, binned them on mine pretty quick, couldn't stop them squealing.
Post #604438 Fri Sep 11 2020 11:15am
SuperC
Thanks Col. What did you go for?
Stuart. Cheers,
Stuart.
Post #604439 Fri Sep 11 2020 11:16am
Currently running EBC Orangestuff H/D SUV pads, but not approved for use in the EU something to do with the way the lining materials attached to the backing plate. I think EBC Yellowstuff is a recommended good alternative.
Post #604440 Fri Sep 11 2020 11:23am
SuperC
Thanks Col. I'm making my mind up on Green or Yellow. Cheers,
Stuart.
Post #604445 Fri Sep 11 2020 12:00pm
DrRob
Stuart
Where are you located roughly? I’ll then send you some pointers...
I’m in Petersfield
Rob Visitor from fullfatrr.com
Post #604446 Fri Sep 11 2020 12:18pm
SuperC
Hi Rob, I'm based in Midhurst so, not far from you. Cheers,
Stuart.
Post #604448 Fri Sep 11 2020 12:47pm
DrRob
OK. Here you go:
1) Petersfield Garage Services and ask that Mark Palmer works on it. He runs a Sport himself and is a big Land Rover enthusiast Thumbs Up He does all the work on mine that I can’t handle and I’m a fussy Censored Rolling with laughter
2) SLR Automotive in Haslemere nr the station
3) AJ LandRover nr Bentley. Archie is a big LR enthusiast too Thumbs Up
Mark P uses EBC Green on his Sport I think 🤔
Post #604455 Fri Sep 11 2020 2:26pm
SuperC
Perfect. Many thanks Rob. Cheers,
Stuart.
Post #604463 Fri Sep 11 2020 4:40pm
DrRob
You’re welcome Thumbs Up
If you use PGS then tell Mark that Rob with the 2 Rangies sent you Thumbs Up Visitor from fullfatrr.com
Post #604477 Fri Sep 11 2020 7:38pm
skid1963
DrRob wrote:
OK. Here you go:
Rob
2nd vote for AJ Landrover nr Bentley/Alton
But be aware his workload is huge, phoned him about 3 weeks ago and couldn't fit me in for 2.5 months Shocked 2015 L494 SDV6 3.0 HSE Loire Blue
2006 L320 4.2 Supercharged
2009 BMW X5 M-Sport - Gone
2007 L320 2.7TDV6 SE Buckingham Blue - Gone
2011 Jaguar XFS 3.0V6 Diesel - Gone
2009 (59) L320 Facelift 3.0TDV6 HSE White Wrap - Gone
2008 BMW X5 M-Sport - Gone
2005 Audi A6 3.2V6 Quattro S-Line - Gone
Post #604490 Sat Sep 12 2020 12:56pm
SuperC
Thanks, appreciate the input. Cheers,
Stuart.
Post #604504 Sat Sep 12 2020 4:41pm
DrRob
Did you get it booked in somewhere? Thumbs Up Visitor from fullfatrr.com
Post #604533 Mon Sep 14 2020 7:04am
