Home > General (L494) > Changed the tyres now key fob doesn't work!
Choudhryz
I have a range rover sport 2015 HSE Dynamic 3.0 SDV6.
Last week 2 tyres were slashed while it was on the driveway. I had the tools so I backed it up took each wheel to the shop and changed the tyres.
After changing both tyres the key fob stopped working and the car is locked.
I thought it was the battery so I went to Timpsons and got it changed but still not working.
So I thought maybe jacking it up activated some lock on the key fob so I opened it manually as you do with the physical key and the alarm blares. I go to deactivate it by putting the fob below the wheel BUT I drive with my steering wheel quite inside and so the area to place the key fob is obscured by the surrounding trim.
Now I have very very expensive parking spot holder.
Does anyone have any solutions?
Post #603905 Sat Aug 29 2020 4:58pm
syl
Don’t you have a spare key? If that doesn’t work then it’s unlikely both keys have failed simultaneously. RRS MY17 SDV6 AB
Evoque MY17 TD4 AB
Post #603907 Sat Aug 29 2020 5:35pm
Choudhryz
No spare key, unfortunately.
Are you sure it's the key?
Post #603909 Sat Aug 29 2020 5:54pm
scrumps
Hi,
Try this :-
https://itstillruns.com/program-key-fob-range-rover-7307259.html
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #603912 Sat Aug 29 2020 7:09pm
