Home > In Car Electronics > Steering wheel upgrade
zeb crs
Norway 2007 Range Rover Sport Supercharged Java Black
I have a 2007 RRS and I have a 2010 steering wheel. I do have all the boards from blackbox to convert so it all works including heat.
But I stumbled over some steering wheel settings in the CCF file that I can select Limbus instead which is the protocol the newer steering wheel uses. Will it work on Limbus then?
Post #603677 Mon Aug 24 2020 8:53am
Why would you want to do that? the conversion works perfectly well including Paddle Shift and Acc with the Can Bus system. The reason I ask is I did this conversion years back and don't re-call changing anything in the CCF files. I also thought although they run along side each other the Can Bus system was better than the Lin Bus at least for certain circuits but could well be totally wrong on that one.
Post #603726 Mon Aug 24 2020 9:42pm
geoffsnook
There is a guy on facebook that is doing the boards at a fraction of the price blackbox charge and the over on Disco3 seem happy with them try searching over there Thumbs Up
Post #603761 Tue Aug 25 2020 5:03pm
Ians63
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Search for Fritjof Dittner on Facebook and contact him through messenger. As already said far cheaper than BBS. RRS 2006
2.7 TDV6
Zermatt Silver
Post #603762 Tue Aug 25 2020 5:32pm
geoffsnook
Hi
I have just fitted one of these. Just to make you aware, there is a guy on the Discovery owners facebook page called Fritjof Dittner who now makes a cheaper version of the conversion PCB's (£52 delivered to UK from Germany).
They are easy to fit and work flawlessly.
Then you can find any D4 steering wheel on ebay etc and convert it yourself.
Ideally for a D3, you don't want paddles or heated. If you do you have to do more...
Post #603763 Tue Aug 25 2020 5:36pm
hogster
Ireland 2006 Range Rover Sport TDV6 SE Bonatti Grey
I have ordered a 2012 spec heated steering wheel and spent hours reading up on this. I need to get the clock spring and the electronics. I was going to use black box but interested to hear theres someone else offering this.
Any links to this seller as I am not on facebook and does he offer use for the heated steering element as BBS does:
https://blackbox-solutions.com/shop/product/ac032
Just found a video of him on youtube:
Post #604776 Tue Sep 22 2020 5:51pm
mgrover
if i understood your post correctly does that mean we can retrofit a heated steering wheel on a first gen L320?
Post #604778 Tue Sep 22 2020 6:41pm
Yes, if you search "heated steering wheel" are plenty of posts on the subject.
Post #604779 Tue Sep 22 2020 6:43pm
hogster
Yea the facelift 2010-2013 RRS steering wheel can be installed to the older 2005-2009 preface but requires a few bits to do it. Its a job I am tackling soon.
Post #604804 Wed Sep 23 2020 9:31am
mgrover
ive got an eye on a steering wheel. ill order it tonight.
then i guess i need the conversion pcbs from black box, the acc accessory thing and heated steering wheel thing. itd be nice if the dude in the video supplier had a shop and i can just get it for £40 but what ya gonna do.
Post #604808 Wed Sep 23 2020 10:25am
Make sure you get the right clock spring there is only one that will do the heated wheel. LR018556
Needs to look like this.
Not this.
Post #604825 Wed Sep 23 2020 9:36pm
mgrover
if the steering wheel is a heated one anyways will it not come with a heated clock spring?
Post #604845 Thu Sep 24 2020 8:38am
No, it's a seperate item unless who ever is selling the wheel is selling one with it.
Post #604846 Thu Sep 24 2020 8:42am
mgrover
fair enough ill make sure to ask. thanks Smile
Post #604848 Thu Sep 24 2020 8:49am
hogster
So the clockspring should be the following:
• Clock spring for heated steering wheel LR018556 (9H22-14A664-AA *UG 11 251 0043 0*)
This part number seems to be more commonly advertised: 9H22-14A664-AA *UG 11 251 0043 0 ?
Post #605011 Mon Sep 28 2020 7:52pm
