![]() | Home > Maintenance & Modifications > Pulling to the Left |
If your tyre's worn, it's only going to go out of track again - so replace the tyre(s) and then see about having the realignment seen to. |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 ![]() ![]() ![]() |
Matt. Essentially best to get the tyres and the geometry corrected at the same time. Never fit expensive new tyres without the alignment being checked. Both processes will be cheaper at your local tyre outlet. LR dealers only send the car out and charge a mark-up. Geometry should be done every six months and worth every penny. Also check ebay: I bought brand new 295/20/40s F1s for about half price and "bunged" the guy at the tyre fitters to do the whole job. Try and find a proper computerised/laser four wheel alignment centre as they adjust camber caster and many other settings for minimal wear and optimum drive. Good Luck! |
Lateral5 Member Since: 07 Jun 2006 Location: Down south Posts: 331 ![]() ![]() |
Pretty common problem, which I have heard solutions ranging from a decent 4W alignment to steering column replacement. Go and get a decent alignment (ie not via stealers) using the standard LR RRS specs and see what happens from there. How are your tyre pressures? RRS TDV6 Bluetooth, VR, Roof ![]() |
mattb Member Since: 08 Feb 2007 Location: Cheshire Posts: 15 ![]() ![]() ![]() |
All sorted now. Have had to replace the tyres on the Front. Very Slow Puncture that got worse. |
