Home > Maintenance & Modifications > ACE /Dynamic Reponse Leak 😔 |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Is it me, or does the outer casing look distorted?
Thu Aug 20 2020 9:15pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8991 |
You can't seal it as it's a hydraulic ram - it moves in and out a bit as it works. 2012 SDV6 - it's missing a couple of cylinders
Thu Aug 20 2020 9:22pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4986 |
Unfortunately looking at the outer casing of the ram those "indentation" around the circumference indicate to me the end cap is crimped in so it is not possible to remove it to replace the seals without re-engineering, assuming you could even get replacement seals. Conventional rams those caps are/were screwed in and when I worked with heavy construction equipment we were for ever resealing hydraulic rams, fitting new piston rods etc. So at L/R prices that will be £1500.00 please, thank you very much Sir.
Thu Aug 20 2020 9:37pm |
From the pictures, I think it's leaking from between the end cap and the casing, not the moving piston. I could be wrong though! Kev MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
Thu Aug 20 2020 10:03pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Moore Automotive Ltd in Chertsey
Fri Aug 21 2020 7:12am |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
I see what you mean - it looks like the end cap is no longer perpendicular to the plane of the bottom of the outer barrel, like it has twisted slightly. Maybe failed ARB bushes allowing the bar ends to try and 'articulate' their way out of the hydraulic unit? 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Fri Aug 21 2020 7:58am |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
If you need to replace the bar it's a body off job. Id check the pipes supplying the bar and if they aren't in great nick get them replaced at same time body is off |
Fri Aug 21 2020 8:12am |
Tilz Member Since: 23 Jul 2020 Location: Harrow Posts: 9 |
Took the plunge and bought a new ARB from Advanced factors. |
Fri Aug 21 2020 1:59pm |
Which is why going to someone like Advanced Factors makes sense. About £600 for the front ARB, £700 for the rear one. That's incl the VAT. Still a non-cheap job, but it's not quite as eye watering as LR's extortionate pricing. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
The right thing to do. These things never really "mend" properly so replacing means that at least you'll have that part out of your mind for a good while onwards. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Aug 21 2020 2:00pm |
^^^ Agreed. Do it once and do it properly.
Fri Aug 21 2020 2:56pm |
Yeah agreed. I’d otherwise always worry about it. Hopefully have it fitted next week. Steering felt heavy so hopefully this is the fix that was needed.
Fri Aug 21 2020 7:06pm |
Good lord, no! I'm not set up to do stuff like that. I've had a rear one replaced before now but done by a garage. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sat Aug 22 2020 6:53am |
Ah fair enough. I don't know why I thought that Kev
Sat Aug 22 2020 11:41am |
