Home > Maintenance & Modifications > Passenger side (UK) rear airbag deflation
Gjlatz
Scotland 2012 Range Rover Sport SDV6 HSE Lux Siberian Silver
2012 SDV6. Morning all, parked the RR in the garage on Saturday and yesterday evening evening decided to go out for a drive. I found that the passenger side rear airbag had completely deflated (photo attached). I have experienced this with P38s but no issues with my L322.
I drove it yesterday and after initial start up the suspension raised quickly and the pump didn't run excessively nor did it run randomly during the drive.
Just checked the RR this morning and it's totally deflated, which I think is pretty quick. With the P38s I would take out the self levelling fuse and check the next day for any deflation and there was then it's an air leak if not then electrical. This was supported by a search of the forum yesterday evening.
Just wondering if anyone has experienced this recently and what was the issue. The forum search lean towards the rear valve but not always. Couple of initial questions for you.
Which fuse is for self-levelling?
The location of the rear valve block?
Many thank
Garry
Post #603483 Thu Aug 20 2020 8:19am
Rear valve block is on the left rear suspension support structure. The EAS fuse is 26E in the engine bay fuse box. It's a 20A fuse. 2012 SDV6 - it's missing a couple of cylinders
Post #603487 Thu Aug 20 2020 9:20am
Gjlatz
Brilliant. Thanks TDV8.
Post #603489 Thu Aug 20 2020 9:36am
