Home > Faults & Fixes > Passive entry
B19CMY
Passive entry
Hi, looking for some advice please.
Rear passenger door won't unlock when you put your hand on it or lock when you press the button on the handle but does give two beeps when you try to lock it. Is this a big fix or maybe a loose connection? Anyone had similar issue?
Cheers! 2012 RRS HSE 3.0 SDV6 Orkney Grey
2009 RRS HSE 2.7 TDV6 Orkney Grey
2006 RRS SE 2.7 TDV6 Zermatt Silver
Post #603078 Mon Aug 10 2020 11:21am
Not uncommon, needs new lock/latch, just replaced my o/s/r for same reason.
Post #603114 Mon Aug 10 2020 8:59pm
B19CMY
Cheers Col, will have a look 👍 2012 RRS HSE 3.0 SDV6 Orkney Grey
Post #603144 Tue Aug 11 2020 2:43pm
