Home > In Car Electronics > Bluetooth, Reverse Cam, Parking Sensors....
ToonArmyMick
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Hi Everyone,
Bit of a strange one this...
A couple of days ago, I left the house to get into the car to go to work, car wouldnt start, battery dead as a dodo. I was running late so didnt have time to investigate there and then. When I came home from work that evening the car started absolutely fine?!?!?!
I took it for a short drive and noticed that the reverse camera, parking sensors and blutetooth are no longer working.
I plan to have a look at all the fuses/relays etc.. tomorrow when I have time, but was just wondering if anyone has experienced similar?
Thanks,
Post #602930 Fri Aug 07 2020 6:02pm
ToonArmyMick
quick update to this...
Checked all fuses, all ok, buetooth and parking sensors are now working again with me doing nothing?!?!
The reverse camera is just a black screen though when R is selected, any ideas anyone?
Thanks
Post #604058 Wed Sep 02 2020 6:52pm
If you just have one camera then maybe a new cam required. Or check it has power.
If you have surround cameras then there is a box somewhere
Post #604060 Wed Sep 02 2020 7:05pm
Might be worth double checking Fuse No.31 in passengers side fuse box. If you do have surround cameras it would be Fuse 65 but would imagine none would work if it was blown, the module for the surround system is under the passengers seat.
Post #604068 Wed Sep 02 2020 8:35pm
