![]() | Home > General > Autobox not staying in manual |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
Do you mean you used the paddles to select a gear? And then it went back to "D" after a period of time? If so, yes, that's normal. 2012 SDV6 - it's missing a couple of cylinders
But if you stick it in Sport and then use the paddles, it stays in manual mode IIRC? Been a very long time since I used the paddles, though (also might be a <=2010 thing)? 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Phil2k Member Since: 18 Jun 2020 Location: Anglesey Posts: 75 ![]() ![]() ![]() |
Mine is a 2013 and does the same |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
Yes if in sport mine will stay in manual, in D after somewhere around 10 seconds after last using the paddles it returns to auto. 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
It will return to D if certain conditions are met.... but I can’t remember what they are. Mine will stay in manual if I’m not moving, no matter how long I wait. It also holds the gear if I’m changing throttle position as if readying for an overtake. If I don’t move the throttle it will return to normal quite quickly. You can also deselect manually by holding the Paddle back for 4 seconds??? 2019 5.0 SC SVA (Current)
This reminds me of the first time a friend drove my car - it was already in Sport mode and he was using the paddles when he uttered the words "Doesn't this thing have a Sport mode?" "Er, you're already in it." *look of intense disappointment* Then he tried to throw it around a corner like he was driving his car ... a Gallardo. I thought we were about to end up in the bushes! 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
